Which drag coefficient is used by default for the calculation of the bubble detachment frequency within the Wall Boiling model?
June 6, 2022 at 8:33 am
FAQParticipantThe calculation of the bubble detachment frequency is based on the evaluation of the bubble rise (terminal) velocity by considering the balance between the buoyancy force and the drag force. To model the exerted drag force on the detaching nucleate bubble a drag coefficient is required. The RPI model uses a drag coefficient and not a factor which is set to unity. This is taken from the work of W.-C. B. Ceumern-Lindenstjerna, “Bubble departure diameter and release frequencies during nucleate pool boiling of water and aqueous NaCl solution,” in Heat Transfer in Boiling, E. Hahne and U. Grigull, Eds., Academic Press and Hemisphere, New York, NY, USA, 1977. This drag coefficient could be altered by the user to any user defined drag law (for example as expressions written Grace or Schiller-Naumann drag laws).
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Mixing Tank Modeling in ANSYS Fluent
- What is the superficial velocity in multiphase flows?
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- How do I use porous media in a multiphase flow?
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
- Hydrodynamics and Wave Impact Analysis
