Tagged: 17, General, mechanical, structural-mechanics
January 25, 2023 at 7:34 am
FAQ
ParticipantOne can find it on Customer Portal Downloads > Current Releases (one can then select required release from the drop down menu: R17.0, R16.0, etc) On Tools tab: Worbench verification Files – Fluids Worbench verification Files – Structures
