When working with Eulerian Wall Film model user is prompted to review the material properties. Which latent heat is used?
June 5, 2023 at 7:05 am
FAQ
ParticipantLatent Heat in EWF is taken from the property of the chosen film material. If the film material happens to be a DPM material, the material type cannot be an inert particle.
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- What is the superficial velocity in multiphase flows?
- Mixing Tank Modeling in ANSYS Fluent
- Hydrodynamics and Wave Impact Analysis
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
- What do “incomplete” DPM particle tracks mean?
- How to obtain the input values for a Rosin-Rammler particle size distribution from measured data?
