When using butt-joint feature for creating solid model with multiple layers in ACP-pre, why there’s always discontinuity or cleavage between the mesh?
May 15, 2023 at 8:32 am
SolutionParticipantTo use butt joint to connect multible layup, we need to create the layers sequentially. Define the plies as: first left ply first right ply second left ply second right ply third left ply third right ply Sea attached model for a sample.
1. 2056859.zip
