When using an own RGP file to define a real gas / wet steam material for use in a CFX simulation, and the material is assigned to the material group “User” only, the solver crashes in the 1st iteration with unphysical values for enthalpies, temperatures and other variables.
Tagged: 17, BCs & Interfaces, cfx, fluid-dynamics, General, materials, MP - Eulerian MP Flow, Real Fluids
January 25, 2023 at 7:17 am
FAQParticipantOne possible reason is the wrong setting of the thermodynamic state of the real gas material. For dry real gas or the vapor component of a dry/wet homogeneous binary mixture real gas, the parameter “Thermodynamic State” must explicitly be set to “Gas”, because otherwise the solver assumes the state to be a “Liquid”, and only the liquid properties of the RGP table are used.
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Mixing Tank Modeling in ANSYS Fluent
- What is the superficial velocity in multiphase flows?
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- How do I use porous media in a multiphase flow?
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
- Hydrodynamics and Wave Impact Analysis
