When trying to use the Lattice Optimization Workflow in R19.2, the “Use density attributes” checkbox is missing in SpaceClaim. Is there a workaround?
April 5, 2023 at 2:31 pm
FAQParticipantThis should be located in the Structures …Options=> Infill Window after clicking on Facets=>Shell tab from the SpaceClaim Utility Menu. One possible solution is to: 1. Ensure that you are clicking on the solid geometry and not faceted geometry. 2. delete all files from %temp% folder 3. rename folder “v192” to “v192_old” located at ~AppDataRoamingAnsys
