- All Categories
- Fluids - Postprocessing
- When trying to apply a .cst with Turbo post-processing to a new results file, the turbo plots and streamwise location variable range aren’t correct. How can this be fixed.
Tagged: 2021 R1, cfd-post, fluid-dynamics, Turbo Post-processing
March 17, 2023 at 8:59 am
FAQParticipantThis can likely be prevented by defining the correct order while setting up the initial model in TurboPre can also help. TurboPre will embed information about the component ordering in the definition file for TurboPost to use. However once the .res file is written, the component ordering can’t be changed. If you already have a .res file, in CFD-Post go to Edit > Options > Turbo and turn on Disable automatic component ordering. Then manually initialize the components. The order in which you initialize will be the component order. Edit the .cst in a text editor and remove the DATA READER section. Then load the .cst file. The turbo plots and streamwise location variable range will now be correct.
- ANSYS Fluent: Scene and Animation Creation
- ANSYS EnSight: Overview of Postprocessing a Fluent Case in EnSight
- ANSYS Fluent: Simulation of a Rotating Propeller – Part 2
- Display Multiple Plots in the Same Scene using Overlays in Fluent
- Use Different Modes for Saving Pictures in Fluent
- Creating a User Surface in ANSYS CFD Post-processing
- How can I hide the legend or colormap for a Fluent plot?
- How do I automatically export figures generated in CFD-Post from Workbench?
- Add Annotation to Graphics Display within Fluent
- How do I display a vector or contour and the mesh lines together via TUI command?
