Tagged: 17, General, mechanical-apdl, structural-mechanics
March 17, 2023 at 9:00 am
FAQ
ParticipantPrecise hidden mode can have problems with intersection of shapes. When this happens, it is best to use /type,wn,6 Z-buffered graphics. Also, do not set the hi res postscript option (that just turns on precise hidden). Quality of the Z-Buffered image can be improved by increasing the internal Z-Buffer resolution using /GFILE or setting the resolution value in the redirect to postscript menu.
