When importing a .msh mesh file into CFX-Pre, I see small faces in the wireframe on interfaces. Why are these there?
March 17, 2023 at 8:57 am
FAQ
ParticipantThis could be due to the Duplicate Node Checking option being on in the Fluent mesh import Advanced Options.
- Skewness in ANSYS Meshing
- How can I select interior faces and other entities that are inside the model?
