When I modify the values of contour legend colors in Simulation, the contour colors are not correct. This behavior only seems to occur with Solution Combinations. Is this a bug?
Tagged: 11, General, Mechanical (f. Simulation), structural-mechanics
March 17, 2023 at 9:00 am
FAQ
ParticipantNo, it is not a bug. If you go back to the original solution branches that are used to make up the solution combination and set those contour legends to be consistent with that of the solution combination contour legend, the resulting contour bands look correct.
- How to resolve “Error: Invalid Geometry”?
