When having a symmetric contact behavior defined along with a contact offset, are both the surfaces moved?
May 15, 2023 at 8:32 am SolutionParticipant SolutionParticipantPlease see the attached documents to access the solution. Attachments:
 1. 2055562.zip
 2. Solution_2055562.pdf
 You are navigating away from the AIS Discovery experience
