- All Categories
- Fluids - Postprocessing
- When extracting monitoring data from a results file, how can I just export just one or two?
June 6, 2022 at 8:33 am
FAQParticipantRun the following command: cfx5mondata – showvars myresults.res (where you replace myresults.res with the actual results file name). You will get a list of all the possible monitoring data for that results file. If you just want a single one you can use the command: cfx5mondata -res myresults.res -varlist “USER POINT,inlet massflow” -out output_file.csv. This will extract the monitoring point data that had been set up to monitor the Mass Flow through the inlet, and send it to a file called output_file.csv. To know what to put in the section after -varlist, this can be seen in the list of variables obtained from the -showvars command above.
- ANSYS Fluent: Scene and Animation Creation
- ANSYS EnSight: Overview of Postprocessing a Fluent Case in EnSight
- ANSYS Fluent: Simulation of a Rotating Propeller – Part 2
- Display Multiple Plots in the Same Scene using Overlays in Fluent
- Use Different Modes for Saving Pictures in Fluent
- Creating a User Surface in ANSYS CFD Post-processing
- How can I hide the legend or colormap for a Fluent plot?
- Add Annotation to Graphics Display within Fluent
- How do I automatically export figures generated in CFD-Post from Workbench?
- How do I display a vector or contour and the mesh lines together via TUI command?
