June 5, 2023 at 7:04 am
FAQ
ParticipantIn order to effectively manipulate the pmdb file in DM and SpaceClaim (once exported from DM as a parasolid),please set the import option “Target Geometry Type” to “DesignModeler”. Otherwise, many operations performed on the import would fail. Please see solution #2046763 for how to extract parasolid file using pmdb file.
- How to resolve “Error: Invalid Geometry”?
