June 6, 2022 at 8:33 amFAQParticipant
Yes, Forte comes with reaction mechanisms. There are three diesel surrogate mechanisms, four gasoline surrogate mechanisms, and one natural gas mechanism included. Please refer to the Forte User Guide for details on the mechanisms, surrogates used, and the options with each mechanism (pseudo gas soot mechanism, soot plus particle tracking, etc.) Licensing the Model Fuel Library is another option that provides access to the latest validated combustion chemistry.
- I am running an electrochemistry simulation in Fluent. How can I access the electrochemistry reaction rates with UDF?
- How do I model humidity in Fluent?
- ANSYS Internal Combustion Engine (ICE): Port Flow Part 1 – Getting Started
- ANSYS Fluent: Describing Non-premixed Combustion using the Steady Flamelet Model
- ANSYS Chemkin-Pro: Reducing a Combustion Mechanism
- Explanations on the warning Maximum / Minimum PDF table enthalpy exceeded in xxx cells (Non-Premixed or Partially-Premixed models)
- Model setup: Setting up chemical reactions
- How do I use the Flamelet Generated Model?
- LES Simulation of Turbulent Flames Using ANSYS Fluent
- How can volume fraction be plotted in a species transport simulation?
