Tagged: 17, fluent, fluid-dynamics, MP - Eulerian MP Flow, multiphase, Other
January 25, 2023 at 7:17 am
FAQParticipantIf a fluid flow through a region where other fluids (e.g. gas-liquid flow) are present, there are two ways to describe the fluid velocity. The first is to use the physical velocity which is the actual and the local velocity of the fluid particles. This is the velocity which could be measured experimentally via Particle Image Velocimetry or Laser Doppler Anemometry and we are solving for it (Momentum transport equation and the related volume fraction equations). The second is the superficial velocity, which is the velocity the fluid would have if it was flowing through the same domain and as if the other phase(s) were absent. The superficial velocity of the vapor phase in gas-liquid system, for example, is equal to the volumetric flow rate of the vapor phase divided by the cross-sectional flow area of a flow device.
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Guidelines for Courant Number for steady and transient simulation.
- Mixing Tank Modeling in ANSYS Fluent
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- How do I use porous media in a multiphase flow?
- What is the superficial velocity in multiphase flows?
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
