January 25, 2023 at 7:17 am
FAQParticipantIn a dispersed multiphase flow, once the particle fluid interaction in DPM, DDPM and Eulerian Models are defined as empirical models for sub-grid particles (e.g.: Schiller Naumann Drag Model), the particle diameter must be much smaller than cell size to account the interaction between phases accurately. If the particle diameter are larger than cell size, you must adopt the Macroscopic Particle Model, in which the interactions between phases are determined as part of the solution. In this case, particles span many fluid cells.
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Guidelines for Courant Number for steady and transient simulation.
- Mixing Tank Modeling in ANSYS Fluent
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- What is the superficial velocity in multiphase flows?
- How do I use porous media in a multiphase flow?
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
