Tagged: 19, contact, General, mechanical, structural-and-thermal, structural-mechanics
March 17, 2023 at 9:00 am
FAQParticipantIt gives priority to the scoped edges/surfaces during meshing to retain the topology.
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
