What is the procedure for setting the receiver for a calculation area in a non-steady-state acoustic analysis?
Tagged: acoustics, compressible-flow, fluent, fluid-dynamics
August 25, 2023 at 12:15 pm
SolutionParticipantPlease refer to the attached document to access the solution.
1. 2044354.pdf
- Skewness in ANSYS Meshing
