What is the meaning of below warning message ? Master Assembly BaseMesh File is not available. You will need to re-mesh to recover the file before re-connecting the mesh
Tagged: 18.2, General, mechanical, meshing, structural-mechanics
April 5, 2023 at 2:32 pm
FAQ
ParticipantScenario: Using Mesh edit features Ans:When you generate mesh under the mesh folder a base mesh is created. When you edit the mesh, a modified mesh is created. If you clear the edited mesh the software reverts to the base mesh (similar to Undo in other software). We only save one copy of the mesh, so if you are using mesh edit and save a model, the mesh after node merge would be saved and the “base mesh” would be lost. The warning is telling the user that you have resumed a previously saved model and that the base mesh is not available. The base mesh can be re-generated if need be by re-generating the mesh.
- How to resolve “Error: Invalid Geometry”?
