What is the meaning of “…Warning: atomization model is not valid for these conditions…” for a flat-fan-atomizer? How to get rid of this warning?
Tagged: fluent, fluid-dynamics, MP - Eulerian MP Flow, multiphase, Other
March 17, 2023 at 8:59 am
FAQParticipantWhat is the meaning of “…Warning: atomization model is not valid for these conditions…” for a flat-fan-atomizer? How to get rid of this warning? This means that the liquid flow is too slow that no instabilities for break up occur. If you increase the mass flow rate or decrease the “Orifice With”, the flow becomes unstable, breaks up and the warning disappears.
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Mixing Tank Modeling in ANSYS Fluent
- What is the superficial velocity in multiphase flows?
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- Guidelines for Courant Number for steady and transient simulation.
- How do I use porous media in a multiphase flow?
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
