What is the meaning of “…warning: …Pressure …less than down-stream pressure -1, or Invalid downstream density -1 Skipping injection…†for a Pressure-swirl atomizer? How to resolve this issue?
March 17, 2023 at 8:59 am
FAQParticipantAtomizers need an initial guess of downstream pressure/density. For that Fluent calculates the virtual origin based on Position (x,y,z), Injector Inner Diameter and Spray Half Angle. This point is used for evaluating an initial guess of downstream pressure/density. If this virtual origin is found outside of the domain you will get the warning message reported. If you move the center point of your atomizer (X,Y,Z-Position) slightly into your domain, the warning disappears and the particles are injected as intended.
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Mixing Tank Modeling in ANSYS Fluent
- What is the superficial velocity in multiphase flows?
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- Guidelines for Courant Number for steady and transient simulation.
- How do I use porous media in a multiphase flow?
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
