What is the influence of the Reference Pressure Location in a Fluent VOF calculation of a closed tank?
January 25, 2023 at 7:17 am
FAQParticipantWhen both the liquid and the gas are incompressible, the Reference Pressure Location (RPL) is needed and has an influence. It should be choosen such that the RPL is at a point that is either always gas or always liquid. In some cases finding such a point might be impossible. Best way is the use ideal-gas law for the gas in this case.
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Guidelines for Courant Number for steady and transient simulation.
- Mixing Tank Modeling in ANSYS Fluent
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- What is the superficial velocity in multiphase flows?
- How do I use porous media in a multiphase flow?
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
