January 25, 2023 at 7:17 am
FAQParticipantThe mean diameter with the same ratio of volume to surface area as the entire ensemble is known as the Sauter mean diameter. The Sauter mean diameter is used in Fluent to describe the interfacial area concentration. This is an important parameter for predicting mass, momentum and energy transfers through the interface between the phases. Population Balance Methods in Fluent allows the predication of the Sauter mean diameter of the disperse phases and hence a more accurate modeling compared to the monodisperse framework.
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Guidelines for Courant Number for steady and transient simulation.
- Mixing Tank Modeling in ANSYS Fluent
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- What is the superficial velocity in multiphase flows?
- How do I use porous media in a multiphase flow?
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
