June 6, 2022 at 9:58 am
FAQ
ParticipantDefine the substeps for proper radiation calculation otherwise you may get negative values. Also, specify an initial temperature for the model around the expected temperature so the solution starts farther from zero. Make sure an offset temperature has been defined (TOFFST).
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
- How can I understand Beam Probe results?
- ANSYS Mechanical: Fatigue Crack Growth Analysis using SMART Crack Growth
