Tagged: cht, Directional fields, Fields, Fluid results, Fluint, LIC, Line integrated Convolution, results, vectors
November 2, 2022 at 9:16 am
Watch & LearnParticipantIn this video, we will see how you can display the direction fields plot (LIC – Line integrated convolution plots), to display directionality on a surface based on the vector. For fluids, direction field is a more advanced display than streamlines. For example, where streamlines produce lines from particle flow, direction field produces a whole image at every step. For thermal results, it shows the heat flux vector field, while for structural results, it displays the displacement vector information.
- Discovery Downloads
- Ansys Discovery – Supported File Formats
- Release Notes- Previous versions
- Importing an Autodesk Fusion 360 Design Study into Ansys Discovery
- Ansys Discovery: Transient Simulation
- Top New Features in Ansys Discovery 2026 R1
- Ansys Discovery: Creating Custom Shortcuts
- Ansys Discovery: Customizing the Ribbon Tab
- Discovery SpaceClaim – Scripting examples
- Ansys Discovery 2025 R1 Capabilities chart
