Tagged: 2D image, capture scene, discovery, image, photo, report, Saved scene, screenshot
November 2, 2022 at 9:16 am
Watch & LearnParticipantIn this video we will see how you can capture and save scenes. You can save images using Scenes to capture model views. A scene can include the model orientation and visibility with material coloring, results display definition including notations and legend, as well as results presentation options. Exported saved scenes are included in the report and can be saved for use outside of the Discovery application in 2D or 3D. To export a particular scene, switch to the simulation from which you want results and then select Export to 2D Image or Export to 3D Image. A save file dialog prompts for a file name and location to save.
- Discovery Downloads
- Ansys Discovery – Supported File Formats
- Release Notes- Previous versions
- Importing an Autodesk Fusion 360 Design Study into Ansys Discovery
- Ansys Discovery: Transient Simulation
- Top New Features in Ansys Discovery 2026 R1
- Ansys Discovery: Creating Custom Shortcuts
- Ansys Discovery: Customizing the Ribbon Tab
- Discovery SpaceClaim – Scripting examples
- Ansys Discovery 2025 R1 Capabilities chart
