Tagged: 16, convergence, Convergence Problems, fluent, fluid-dynamics, Species/Reactions
January 25, 2023 at 7:17 am
FAQParticipantThe DASAC ODE solver is used for the direct integration of the chemistry. The messages regarding the DASAC failure suggests that the ODE solver (DASAC) failed to integrate the stiff ODEs, and that your solution is not converging well. If you see these messages during the initial few iterations, but notice them go away shortly after, there is no need to worry as the solver is trying to build your solution from the initial conditions specified. However, if you continuously see these messages even after running the solution for a sufficiently large number of iterations, then it means something is wrong with the setup/initial conditions. Most of the time, we can get rid of these messages by specifying a good initial solution (e.g., solution obtained from Finite Rate/Eddy Dissipation model using global reactions). You can also check the material properties, especially the specific heat polynomial coefficients. Use of correct properties will help to avoid these failures. Lastly, your reaction mechanism will also affect the DASAC integration. Please check if the reaction mechanism is correct. If you are using a CHEMKIN import, please make sure that the units mentioned in the CHEMKIN file is correct.
- How do I model humidity in Fluent?
- Configuring and Solving the Chemical Species Transport in Fluent
- ANSYS Fluent: Describing Non-premixed Combustion using the Steady Flamelet Model
- ANSYS Internal Combustion Engine (ICE): Port Flow Part 1 – Getting Started
- Model setup: Setting up chemical reactions
- How do I use the Flamelet Generated Model?
- How can volume fraction be plotted in a species transport simulation?
- ANSYS Chemkin-Pro: Reducing a Combustion Mechanism
- I am running an electrochemistry simulation in Fluent. How can I access the electrochemistry reaction rates with UDF?
- Explanations on the warning Maximum / Minimum PDF table enthalpy exceeded in xxx cells (Non-Premixed or Partially-Premixed models)
