Tagged: fluent, fluid-dynamics, MP - Particle Tracking, multiphase, Other
March 17, 2023 at 1:11 pm
SolutionParticipantThe FLUENT DPM (Discrete Phase Model) allows the user to compute the flow for a set number of discrete particle trajectories dispersed in a continuous phase. The momentum of a particle’s trajectory is implicitly determined from the user-inputted value for the total Mass Flow Rate for the specified DPM, and is theoretically defined as the ‘number of particles injected per unit time’ in a single trajectory. The volume fraction of the discrete phase dispersed in the larger, continuous phase can be considered as the ‘density of particles in a single cell’. This volume fraction can be implicitly calculated from the above ‘number of particles injected per unit time’. Please note that the DPM model in ANSYS Fluent assumes that the second phase is sufficiently dilute that particle-particle interactions and the effects of the particle volume fraction on the larger phase are negligible; therefore, the volume fraction of the discrete phase has no impact in the DPM.
1. 2042212.pdf
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Mixing Tank Modeling in ANSYS Fluent
- What is the superficial velocity in multiphase flows?
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- How do I use porous media in a multiphase flow?
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
- Hydrodynamics and Wave Impact Analysis
