Tagged: 2019 R3, General, mechanical, structural-mechanics
March 17, 2023 at 9:00 am
FAQParticipantThis information message is an internal string ID used by the program which shows up in the Meshing process and says that “The default Error Limit for Mechanical Physics Preference has changed to Aggressive Mechanical in 2019 R3”. In future versions, one should see the entire message stated above instead of just a string ID.
