Tagged: 11, General, Mechanical (f. Simulation), structural-mechanics
March 17, 2023 at 9:00 am
FAQ
ParticipantWhen a run completes successfully (based on Solution Information), but then gives a “General solver error,” it usually means Simulation could not find the results file. Additional information might be available in file.err (in the solver directory). This directory should also contain the file.rst.
