January 25, 2023 at 7:17 am
FAQParticipantIf, when performing Steady DPM trajectory calculations in Fluent, the maximum number of steps are reached and a given particle still does not reach the outlet (or escape/trap boundary), that particle’s fate is reported as incomplete. To avoid a large number of incomplete particles, it is suggested to increase the value of “Max. Number of Steps” in the DPM panel. If increasing the number of maximum steps still results in a large number of incomplete particles, check if a larger re-circulation region is present in the solution. In such a case, it is probable that particles are kept churning in the re-circulation region and are not coming out of the domain, thus reported as incomplete. A large number of incomplete particles may also be caused by the non-converged flow field. In such a case, it might be useful to converge the flow without DPM, then inject the particles and iterate further. Most of the time, a large number of incomplete particles will affect the convergence and speed of the calculation. Therefore, a lower number of incomplete particles is desirable.
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Guidelines for Courant Number for steady and transient simulation.
- Mixing Tank Modeling in ANSYS Fluent
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- How do I use porous media in a multiphase flow?
- What is the superficial velocity in multiphase flows?
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
