Tagged: 2019 R2, General, mechanical, structural-mechanics
January 25, 2023 at 7:34 am
FAQParticipantThis warning message means stiffness matrix of the model is ill-conditioned. Some elements have severe differences in stiffness from other elements. The ill-conditioned matrix can occur due multiple reasons such rigid body motion, highly distorted elements, high frictional contacts, units that may results in numbers too big/small, or even unstable material models.
