What causes the warning below and how to overcome it?: Reference Direction Computation: Alternate method used in Oriented Selection Set
Tagged: 19.1, ANSYS Composite PrepPost, General, structural-mechanics
April 5, 2023 at 2:32 pm
FAQ
ParticipantThis warning is coming from the fact that the x direction of a rosette is projecting onto the element as a point since it is normal. In this case ACP does not know how to orient the x, so it warns it is using a different method. To resolve this we need to have a rosette that does not have the x direction normal to any elements in that oriented element set.
