What causes the message: Error: Normal of target element xxxxxx is not consistent with the normal of target element xxxxx” ?
March 17, 2023 at 9:00 am
FAQ
ParticipantOne possible cause is during a thin sweep meshing step, if source and target faces have dissimilar areas that are ‘corrected’ with Virtual Topology (VT) cells, this might trigger inconsisent normals in contacts and targets. This is a limitation. As a workaround, try removing the VT cells and/or changing the underlying body meshing strategy.
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
- How can I understand Beam Probe results?
- ANSYS Mechanical: Fatigue Crack Growth Analysis using SMART Crack Growth
- How to define frictional coefficient as a function of relative sliding velocity
