June 5, 2023 at 7:05 am
FAQParticipantThe expert parameter “pt minimum diameter” is used to eliminate small particles in a particle evaporation model. The default solver units are SI and thus “pt minimum diameter” is assumed to be in [m]. As units can be set to whatever system is desired in CFX-Pre and CFX-Post, there is really no need to change the default solver units from SI.
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Guidelines for Courant Number for steady and transient simulation.
- Mixing Tank Modeling in ANSYS Fluent
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- How do I use porous media in a multiphase flow?
- What is the superficial velocity in multiphase flows?
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
