March 17, 2023 at 1:12 pm
SolutionParticipantThis document lists all boundary conditions used in Maxwell, which are used to define the behavior of the electric or magnetic field at object interfaces or outer boundaries of the problem region. It is always necessary in order to ensure the uniqueness of the electromagnetic field solution, and it is important to define correct boundary conditions to obtain the right solution for a given electromagnetic problem.
1. EM_FAQ_BoundaryConditionsinMaxwell.pdf
- Cloud Computing from Electronics Desktop
- How to enable GPU acceleration in Electronics Desktop?
- How to import/export an Ansys Maxwell model in Workbench?
- How to fix messed up Windows layout?
- Electric Motor Design Using Ansys Motor-CAD – Part 1
- What are the available boundary conditions in Maxwell?
- How do I calculate inductance and resistance of a coil in post-processing phase?
- How to create and manage a queue of simulations?
- ANSYS Electronics Desktop: Simple Communications Channel For Signal Integrity Analyses – Part III
- Are solid losses and eddy losses the same in Maxwell?
