March 17, 2023 at 9:01 am
FAQParticipantWarning message: “Dell Precision Optimizer – Reboot Required The following policy requires your system to be restarted for the changes to take effect. Profile: Workbench by ANSYS or Fluent by ANSYS Policy: CPU Optimizations” To avoid to get this message, the Optimizer trying to improve performances, go to the ​”Profiles” tab of the Dell Precision Optimizer panel on your machine, and find the “Workbench by ANSYS” or “Fluent by ANSYS” profile in the list of Active Profiles to switch it ‘off’. This should stop the message from appearing again.
