May 15, 2023 at 8:32 am
SolutionParticipantSpaceClaim can extract the volume within a hollow or shelled solid. The attached video demonstrates how to do a Volume Extract as well as update the Volume Extract.
1. 2052892_Captions-EN.mp4
