General
General
Vertex values for Variable XXXX do not exist on Geometry YYYY
    • FAQFAQ
      Participant
      The given error message can occur in CFD-Post when the evaluation of the variable XXXX has resulted in an error. Assume a user defined variable myHTC is defined by an expression qwall/(T-Tref). If T is identical to Tref at any location on the locator YYYY, then a division by zero occurs. This may result in the above error message. Workaround is to ensure that no invalid result is possible for the used CEL expression.
