June 5, 2023 at 7:04 am
FAQ
ParticipantThis is by design. Starting at R18.0, KEYOPT(10) assignments have been redefined. Hence, the automatic reset is necessary. At R18.0, KEYO(10)=2 and KEYO(10)=0 both update the stiffness, except actual elastic slip does not exceed max allowable limit (SLTO) over the entire solution (for (10)=2) vs within a substep (for (10)=0). This is documented, but might not be obvious to the casual observer.
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
- How can I understand Beam Probe results?
- ANSYS Mechanical: Fatigue Crack Growth Analysis using SMART Crack Growth
