Using UPF (User Programmable Features) to run a Fortran subroutine but why doesn’t Mechanical APDL use the UPF?
June 6, 2022 at 9:58 am
FAQParticipantMake sure that these system variables are present. If not, then should be added
C:WindowsSystem32 C:Windows C:WindowsSystem32Wbem C:WindowsSystem32WindowsPowerShellv1.0
