Using the mixing template my solution diverges due to highly skewed meshes in between the impeller and the shaft. Why is this happening?
Tagged: 18.2, BCs & Interfaces, fluent, fluid-dynamics, materials, rotating-machinery
April 5, 2023 at 2:32 pm
FAQ
ParticipantThe skewed meshes are created because the origin is at the not at the centroid/center of Hub. The recommendation is to use a workflow that puts the global coordinate system at the centroid of the impeller. This will avoid the skewed mesh.
- Skewness in ANSYS Meshing
