Using Custom Node Groups and Templates with Icepak and submitting to a Microsoft Cluster If you are submitting Icepak jobs to a Microsoft Compute Cluster and you have Node Groups or Templates defined besides the “default” node groups and templates and you want Icepak to use the Node Groups or Templates you have defined you will need to set these variables.
Tagged: 18.1, hpc, HPC/Parallel, Icepak - SYS, Installation/Licensing/Systems
June 5, 2023 at 7:05 am
FAQParticipantNode Groups (set this variable with the name of your custom Node Group) FL_CCP_NODE_GROUP=
Templates (set this variable with the name of your custom Template) FL_CCP_JOB_TEMPLATE=
