User getting error that Workbench is not installed /ansys_inc/v201/Framework/bin/Linux64/runwb2 is not installed [FAILED]
March 17, 2023 at 9:00 amFAQParticipant
Please check the install.log and install.err for possible errors during installation. Also, confirm the installation location. It is possible that someone has manually moved the media after installation. Run this command as root: /ansys_inc/v201/ProductConfig.sh -silent to reconfigure all Ansys Products in new location.
- Q: How do I set the license server from my client machine?
- Failover feature ‘Discovery – Level 1’ is not available
- How do I configure RSM to send a solve to a remote machine (no scheduler)?
