Under the section 3.2.1. Host Configuration Set to Run Autodyn in Parallel, how to change the cores -how is it related to CPUs?
March 17, 2023 at 8:59 am
FAQParticipant“CPU =” represents how many cores are used from the host machine “host 1” or “host 2” specified in the line just above. If multiple computers are used in the parallel configuration, “speed =” represents the relative clock speed of the CPU in each computer. Autodyn program will conduct load balancing automatically between these computers based upon CPU speed and memory size to get the best parallel performance.
