March 17, 2023 at 8:59 amFAQParticipant
Keywords: Cadence, Spaceclaim, brd, mcm, sip Cadence terminates import into SCDM starting from v19.2, that’s why you can’t import Cadence file to SCDM in 2019 R1. There are 2 workarounds: 1. In Cadence output the Cadence as a tgz file and SCDM can read tgz file. 2. If you have version older than 19.1, read the BRD file into 19.1. Save the model and open it in 2019 R1.
- The LS-DYNA equivalent of *MODEL_CHANGE card (in ABAQUS). Which keywords can be used to introduce(activate)/delete(deactivate) elements in the middle of a calculation (at user-specific time/load steps).
- How to resolve “Error: Invalid Geometry”?
- After Workbench crashes, how can I recover the project from a .mechdb file?
- Model has a large number of contacts – how to reduce them?
