August 25, 2023 at 12:16 pm
SolutionParticipantThis video provides and overview of the new reporting features added to ANSYS License Management Center. Please refer to the attachment to access the Solution.
1. v_Lic_LMCenter_Reporting_Overview_180.mp4
