Tagged: 2020 R1, cfd-post, fluid-dynamics, Turbo Post-processing, turbomachinery
April 13, 2023 at 7:32 am
SolutionParticipantFor specific turbomachineries, there could be an inlet suction part without whole Hub turbo region (Spinner, Cone). In that case the default turbo initialization won’t succeed. It needs to use the option From Line to represent the “Hub” region. Please see the attached document.
1. 2063041.pdf
- Rocky GPU Buying Guide
- Skewness in ANSYS Meshing
