Tagged: 18, cfx, cht, fluid-dynamics, Heat Transfer and Radiation, Modeling/Setup Advice
June 5, 2023 at 7:05 am
FAQParticipantProblems with a CHT analysis in CFX can manifest themselves as unphysically high temperatures in a solid due to poor mesh quality of that solid. If very high temperatures are generated, use CFD-Post to isolate the location of concern then check the mesh quality in this area. If the minimum orthogonality angle is less than 10 degrees in this area, try to remesh it to improve the quality. It has also been shown that resolving the temperature gradient near the interface with inflation layers will help. Unphysically high temperatures near the fluid solid interface can also be caused by the use of 1:1 interfaces. A conformal mesh can be used for CHT cases, however if unphysically high temperatures are encountered, GGI interfaces should be used. If convergence problems and/or unphysical temperature peaks persist the recommendation is to change the diffusion scheme used with the CHT model. To do this, you need to use the expert parameter ‘”cht diffusion scheme”. A more robust but less accurate scheme (positive definite values) is used if the parameter is set to: EXPERT PARAMETERS: cht diffusion scheme = 3 END
- Defining heat transfer coefficient (HTC)
- How to use Thin Walls with Thermal boundary conditions?
- ANSYS Fluent Student: Conjugate Heat Transfer in a Heat Sink
- How to solve the warning: “Warning: zone of type interior found between different solids!”
- Setting Operating Density for Natural Convection cases when density is modelled using Ideal gas law
- ANSYS Fluent: Overview of the Mapped Interface Technique for CHT Simulations (18.2)
- How do I get rid of convergence problems with energy equation in Fluent (especially since R15)?
- In ANSYS Fluent, when the energy equation is enabled and viscous heating is enabled, must pressure work also be turned on?
- Thermal Analysis of a Radiator Using Ansys Fluent
- In Fluent, how can we reduce the time for an unsteady simulation of a Conjugate Heat Transfer (CHT) simulation? Is there any way to give different time steps for fluid and solid in a single simulation?
