Tagged: 2019 R3, General, mechanical, structural-mechanics
March 17, 2023 at 9:00 am
FAQParticipantThis error message usually means that two or more environments are linked (e.g. static structural linked to modal) and the downstream environment is being solved in a unit system than is different from the unit system that was used to solve the upstream environment. To resolve this error, you can find the unit system in upstream analysis by checking its solve.out file and then use the same solving unit in the downstream analysis. If you would like to use another unit system, you will have to clear generated data for the upstream analysis and solve both upstream and download analyses with the new unit systems.
